Model.attributeupdateentityidarrayelementmark#
- Model.attributeupdateentityidarrayelementmark(collection, identifier, solver, status, behavior, target_entity, index, value)#
Updates one element of an attribute of type 2D entity ID array.
- Parameters:
collection (Collection) – The collection containing the entities that owns the attribute.
identifier (int) – The identifier of the attribute.
solver (int) – The solver number of the attribute.
status (int) – The status of the attribute.
behavior (int) – The behavior of the attribute.
target_entity (EntityFullType) – The type of entity to which the attribute refers.
index (int) – Index into the array (first index is zero).
value (unsigned int) – The new value of the 2D array element.
Example#
Update the load collector with ID 14 , 78 in * CNVGADD_CONVGID * dataname (identifier=718) in Optistruct profile by set the load collectors with ID 5#import hm import hm.entities as ent model = hm.Model() # Finding the CNVGADD_CONVGID identifier using the hm_attributeidentifier function _, r = model.hm_attributeidentifier( entity_type=ent.Loadcol, entity_id=14, attribute_name_or_id="CNVGADD_CONVGID" ) # Setting the dataname model.attributeupdateentityidarrayelementmark( collection=hm.Collection(model,ent.Loadcol,[14, 78]), identifier=r.id, solver=1, status=2, behavior=0, target_entity=ent.Loadcol, index=0, value=5, )
