Model.hm_getactiveplotcontrolminvalue#
Model.hm_getactiveplotcontrolminvalue(plot_type, collection)#
Returns the minimum value for the active plot control together with the entity. There can be only one active plot control for every plot type.
Parameters:
  • plot_type (hwString) – The type of plot for which the result values are queried. Valid values are contour, vector, and tensor.
  • collection (Collection) – The collection containing the entities that are considered for evaluation.
Returns:
  • hwReturnStatus - Status object
  • HmQueryResult - Result object containing the output values:
    • entity (Entity) - The entity for which the minimum value is returned.
    • value (float) - The minimum value for the active plot control.
Note
If the function is used as part of a script that creates the queried plot, it is required to call Model.hm_redraw before using this function to ensure the graphics are refreshed and the data can be extracted.
Example#
Get the minimum value for the active contour plot control for a collection of displayed nodes#
import hm
import hm.entities as ent
model = hm.Model()
nodes = hm.CollectionByDisplayed(model, ent.Node)
_, result = model.hm_getactiveplotcontrolminvalue(plot_type="contour", collection=nodes)
print("Entity ID:", result.entity.id)
print("Minimum Value:", result.value)
