Model.beamsectiontranslate#
- Model.beamsectiontranslate(beam_sect_id, translate_option, translation_y, translation_z)#
The beam section specified will be translated by the amounts specified by
translation_yandtranslation_z, or be centered at the centroid or the shear center of the beam depending on the option specified bytranslation_option. The beam must be of type shell or solid.- Parameters:
beam_sect_id (unsigned int) – The ID of the shell or solid beam section to update.
translate_option (int) –
0 - The section will be translated by the amounts specified by
translation_yandtranslation_z.1 - The section will be centered at the location of the centroid.
2 - The section will be centered at the location of the shear center.
translation_y (double) – Amount of translation in the local y direction of the beam for a
translation_option=0.translation_z (double) – Amount of translation in the local z direction of the beam for a
Examples#
Translate a beam section with ID 1 to be centered at its shear center#import hm model = hm.Model() model.beamsectiontranslate( beam_sect_id=1, translate_option=2, translation_y=0.0, translation_z=0.0 )
Translate a beam section with ID 1 by 1.0 in the local y direction and 2.1 in the local z direction#import hm model = hm.Model() model.beamsectiontranslate( beam_sect_id=1, translate_option=0, translation_y=1.0, translation_z=2.1 )
