Model.hm_markbyfeature#
- Model.hm_markbyfeature(input_collectionset, output_collectionset, feature_mode, min_radius=0, max_radius=0, internal_only=0, closed_cylinder=0, valve_output=1)#
Puts entities on the specified output collection based on entities on the input collection selection and specified feature parameters.
- Parameters:
input_collectionset (CollectionSet) – The set of collections containing possibly multiple type of entities of the input collection.
output_collectionset (CollectionSet) – The set of collections containing possibly multiple type of entities of the output collection.
feature_mode (int) –
This is mandatory input parameter. Valid values are:
1 - Put on output collection lines representing circles. Input collection entity type is line.
2 - Put on output collection lines representing circles. Input collection entity type is surface.
3 - Put on output collection surfaces representing cylinders. Input collection entity type is surface.
4 - Put on output collection surfaces representing fillets. Input collection entity type is surface.
5 - Put on output collection surfaces representing valve seats. Input collection entity type is surface.
6 - Put on output collection surfaces that contain internal discontinuities and high curvature areas. Input collection entity type is surface.
min_radius (double) – This parameter filters output lines or surfaces by minimal curvature radius. Valid values are any value > 0.0, or a value < 0.0 to specify any radius.
max_radius (double) – This parameter filters output lines or surfaces by maximum curvature radius. Valid values are any value > 0.0, or a value < 0.0 to specify any radius.
internal_only (int) – Used only for
feature_mode=1orfeature_mode=2. If set to 1, all outer circles on surfaces will be excluded from the output.closed_cylinder (int) – Used only for
feature_mode=3. If set to 1, all non closed cylinder surfaces will be excluded from the output.valve_output (int) – Used only for
feature_mode=5. If set to 1, all surfaces representing the cylinder part of a valve seat will be excluded from the output.
- Returns:
hwReturnStatus- Status object
Examples#
Populate a CollectionSet with lines representing circles with radius between 1.0 and 15.0#import hm import hm.entities as ent model = hm.Model() inputCollectionSet = hm.CollectionSet(model) all_lines = hm.Collection(model,ent.Line) inputCollectionSet.set(all_lines) outputCollectionSet = hm.CollectionSet(model) model.hm_markbyfeature( input_collectionset=inputCollectionSet, output_collectionset=outputCollectionSet, feature_mode=1, min_radius=1.0, max_radius=15.0 ) if outputCollectionSet.empty: print("No lines representing circles with radius between 1.0 and 15.0 found") else: lines = outputCollectionSet.get(ent.Line) print("Number of lines representing circles with radius between 1.0 and 15.0:", len(lines))
Populate a CollectionSet with surfaces representing closed cylinders with any radius#import hm import hm.entities as ent model = hm.Model() inputCollectionSet = hm.CollectionSet(model) all_surfaces = hm.Collection(model,ent.Surface) inputCollectionSet.set(all_surfaces) outputCollectionSet = hm.CollectionSet(model) model.hm_markbyfeature( input_collectionset=inputCollectionSet, output_collectionset=outputCollectionSet, feature_mode=3, min_radius=-1.0, closed_cylinder=1 ) if outputCollectionSet.empty: print("No surfaces representing closed cylinders found") else: surfaces = outputCollectionSet.get(ent.Surface) print("Number of surfaces representing closed cylinders with any radius:", len(surfaces))
