Model.voxel_lattice_hex_mesh_remove_volume#
Model.voxel_lattice_hex_mesh_remove_volume(x, y, z)#
Removes a volume surrounding a given point from the voxel domain. The volume is determined by the elements that are part of the domain when this function is run. This must be preceded by a call to Model.voxel_lattice_hex_mesh_init() and must be followed by a call to Model.voxel_lattice_hex_mesh_create().
Parameters:
  • x (double) – The x-coordinate of the point inside the volume.
  • y (double) – The y-coordinate of the point inside the volume.
  • z (double) – The z-coordinate of the point inside the volume.
Example#
Create voxels of size 10.0 to include components with IDs 100 - 110 and remove the volume surround ( 50,50,50 )#
import hm
import hm.entities as ent
model = hm.Model()
# Creating a collection that contains the components to be included
filter_in_components = hm.FilterByEnumeration(ent.Component, list(range(100, 111)))
in_component_collection = hm.Collection(model, filter_in_components)
model.voxel_lattice_hex_mesh_init(voxel_size=10.0)
model.voxel_lattice_hex_mesh_add_entities(collection=in_component_collection, mode=1)
model.voxel_lattice_hex_mesh_remove_volume(x=50.0, y=50.0, z=50.0)
model.voxel_lattice_hex_mesh_create()
model.voxel_lattice_hex_mesh_end()
