Model.hm_nodeismidnode#
- Model.hm_nodeismidnode(node_entity)#
Checks if a node is a mid-side node on a second-order element. Returns True for a mid-side node, False otherwise.
- Parameters:
node_entity (Entity) – The object describing the node entity to check.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:isMidNode (bool)
Example#
Check if node with ID 99 is a mid - side node#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_nodeismidnode(node_entity=ent.Node(model, 99)) print("isMidNode", result.isMidNode)
