Model.hm_getmodelcheckconcernentityidresultentityid#
- Model.hm_getmodelcheckconcernentityidresultentityid(display_name, contact_id)#
This functon returns the concerned non projecting untied nodes for a given contact group/interface.
- Parameters:
display_name (hwString) –
The display name of the check to query. Currently supported values are:
”Un-Tied nodes in Contact Tied” for LS_DYNA
”Un-Tied nodes in interface type2” for Radioss
contact_id (int) – ID of the contact for which untied nodes are to be found. This must be one of the contact IDs listed in the Model Checker browser after a Model Checker run.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:untiedNodes (EntityList) - Entity list object containing Entity Type
Node
Examples#
Get untied nodes for contact with ID 123 for LS_DYNA#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_getmodelcheckconcernentityidresultentityid( display_name="Un-Tied nodes in Contact Tied", contact_id=123 ) print("untiedNodes:", result.untiedNodes)
Find untied nodes for contact with ID 123 for Radioss#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_getmodelcheckconcernentityidresultentityid( display_name="Un-Tied nodes in interface type2", contact_id=123 ) print("untiedNodes:", result.untiedNodes)
