Model.attributeupdatestringarray#
Model.attributeupdatestringarray(entity, identifier, solver, status, behavior, value)#
Updates an attribute of type string array (hwStringList()).
Parameters:
  • entity (Entity) – The object describing the entity that owns the attribute.
  • identifier (int) – The identifier of the attribute.
  • solver (int) – The solver number of the attribute.
  • status (int) – The status of the attribute.
  • behavior (int) – The behavior of the attribute.
  • value (hwStringList) – The value of the attribute.
Example#
Update the load collector with ID 74 in * IMPERF_NRES_STR * dataname (identifier=11344 ) in Optistruct profile by set attribute to [ ‘ LAST ‘ , ‘ INTEGER ‘ , ‘ LAST ‘ ]#
import hm
import hm.entities as ent
model = hm.Model()
# Finding the IMPERF_NRES_STR identifier using the hm_attributeidentifier function
_, r = model.hm_attributeidentifier(
    entity_type=ent.Loadcol, entity_id=74, attribute_name_or_id="IMPERF_NRES_STR"
# Setting the dataname
model.attributeupdatestringarray(
    entity=ent.Loadcol(model, 74),
    identifier=r.id,
    solver=1,
    status=2,
    behavior=0,
    value=[
        'LAST',
        'INTEGER',
        'LAST',
