Model.CE_ReviewLinks#
- Model.CE_ReviewLinks(collection, operation_type, output_collectionset, consider_geom=True, consider_HAZ_elems=True, find_twince_option=1, filter_projection_entities=0)#
Reviews links according to user options.
- Parameters:
collection (Collection) – The collection containing the connector entities to review.
operation_type (hwString) –
The string for the type of operation to be performed: “find”, “findattached”, “findbetween”, “hide”, “isolate”, “isolateonly” and “show”.
To operate on between links: “cebetween_hide”, “cebetween_isolate”, “cebetween_isolateonly” and “cebetween_show”.
output_collectionset (CollectionSet) – The set of collections containing possibly multiple type of entities onto which reviewed entities are placed.
consider_geom (bool) – Defines if geometry is also considered along with elements during show/hide/isolate operations. Valid values are true and false.
consider_HAZ_elems (bool) – Defines if HAZ (Heat Affected Zone) elements should also be considered during show/hide/isolate operations. The possible values are true and false.
find_twince_option (int) –
Find twin connectors according to:
1 - Minimum two links
2 - Exact links
filter_projection_entities (int) –
Filters links to the projection entities during show/hide/isolate operations, according to following options which are possible values:
0 - None
1 - Projection components
2 - Projection elements
3 - Projection and attached elements
Example#
Isolate components with ID 2 and 4 with no overwritten user options#import hm import hm.entities as ent model = hm.Model() InputCollectionSet = hm.CollectionSet(model) component2 = hm.Collection(model, ent.Component, [2]) component4 = hm.Collection(model, ent.Component, [4]) InputCollectionSet.set(component2) InputCollectionSet.set(component4) OutputCollectionSet = hm.CollectionSet(model) model.CE_ReviewLinks( collection=InputCollectionSet, operation_type="isolate", output_collectionset=OutputCollectionSet, consider_geom=True, consider_HAZ_elems=True, find_twince_option=0, filter_projection_entities=2 )
