Model.setelemqualityparamactive#
- Model.setelemqualityparamactive(param_id, active)#
Sets the on/off state for a specified element quality parameter. This function is related to the element quality view mode.
- Parameters:
param_id (int) –
Specifies the element quality check parameter ID to update. Valid values are:
0 - min size
1 - max size
2 - aspect ratio
3 - warpage
4 - max interior angle quad
5 - min interior angle quad
6 - max interior angle tria
7 - min interior angle tria
8 - skew
9 - Jacobian
10 - chordal deviation
active (int) –
0 - Inactive/off
1 - Active/on
Examples#
Activate “warpage” parameter#import hm import hm.entities as ent model = hm.Model() model.setelemqualityparamactive(param_id=3, active=1)
Disable “Jacobian” parameter#import hm import hm.entities as ent model = hm.Model() model.setelemqualityparamactive(param_id=9, active=0)
