Model.interfaceaddsolidface#
Model.interfaceaddsolidface(name, main, element_collection, node_collection, break_angle)#
Creates interface elements on shell elements and faces of solid elements.
Parameters:
  • name (hwString) – The name of the group into which the interface elements should be placed.
  • main (int) –
    0 - For secondary elements.
    1 - For main elements.
  • element_collection (Collection) – The collection containing the input solid element entities.
  • node_collection (Collection) – The collection containing the node entities that define the face of a solid element.
  • break_angle (double) – The angle used to define a “sharp corner”.
Note
HyperMesh will use the node_collection to find the face of a solid element. All adjacent faces will then be found until a sharp corner (defined by break_angle) is found. Finally, main/secondary elements will be created on these faces.
Example#
Create interface elements on shell elements and faces of solid elements and place them into set with name “ group1 “#
import hm
import hm.entities as ent
model = hm.Model()
# Selecting elements and face nodes via interactive selection
elem_collection = hm.CollectionByInteractiveSelection(model, ent.Element)
face_node_collection = hm.CollectionByInteractiveSelection(model, ent.Node)
model.interfaceaddsolidface(
    name="group1",
    main=1,
    element_collection=elem_collection,
    node_collection=face_node_collection,
    break_angle=0,
