Model.pressureonelement_curve#
- Model.pressureonelement_curve(entity, face_index, x_comp, y_comp, z_comp, magnitude, curve_id, x_scale)#
Creates a pressure load on an element.
- Parameters:
entity (Entity) – The object describing the element entity on which to apply the pressure.
face_index (int) – The face index of the solid element. Ignored, if the element is a shell element.
x_comp (double) – The x-component of pressure.
y_comp (double) – The y-component of pressure.
z_comp (double) – The z-component of pressure.
magnitude (double) – The magnitude of the pressure.
curve_id (unsigned int) – The ID of a curve defining the magnitude of the load versus time.
x_scale (double) – A scale factor applied to the x-axis (or time axis) of the curve.
Example#
Apply a pressure of magnitude 4.0 on the solid element ID 10 face index with ID 2 , use the curve with ID 9 to vary the magnitude over time#import hm import hm.entities as ent model = hm.Model() model.pressureonelement_curve( entity=ent.Element(model, 10), face_index=2, x_comp=0.0, y_comp=0.0, z_comp=0.0, magnitude=4.0, curve_id=9, x_scale=1.0, )
