Model.duplicateentities#
Model.duplicateentities(input_collection, output_collection, destcomponent, destloadcol, transformloads=0, reverseloads=0)#
Duplicates elements, nodes and components along with any attached loads.
Parameters:
  • input_collection (Collection) – The collection containing the entities to duplicate. Valid entities are elements, components, nodes.
  • output_collection (Collection) – The collection containing the new entities.
  • destcomponent (unsigned int) –
    Required option.
    1 - New component.
    2 - Current component.
  • destloadcol (unsigned int) –
    Valid only if transformloads=1. Required option.
    1 - New load collector.
    2 - Current load collector.
  • transformloads (int) –
    0 - Do not transform loads. (default)
    1 - Transform loads.
  • reverseloads (int) –
    0 - Do not reverse loads. (default)
    1 - Reverse loads.
Examples#
Duplicate the element with ID 1 and place the new element in the current component#
import hm
import hm.entities as ent
model = hm.Model()
# Creating a collection that contains the elements to duplicate
element_collection = hm.Collection(model, ent.Element, [1])
# Creating an empty collection
output = hm.Collection(model, ent.Element, populate=False)
model.duplicateentities(
    input_collection=element_collection,
    output_collection=output,
    destcomponent=2,
    destloadcol=1,
Duplicate all elements , place the elements in a new component , and transform the loads and place them in a new load collector#
import hm
model = hm.Model()
element_collection = hm.Collection(model, ent.Element)
    destcomponent=1,
    destloadcol=2,
    transformloads=1,
