Model.elementqualityplacenodenew#
Model.elementqualityplacenodenew(node_id, x, y, z, normal_flag=0, boundary_flag=0, midnodes_flag=1)#
Moves the specified node to a target point. This function only functions between an Model.elementqualitysetup() function and an Model.elementqualityshutdown() function.
Parameters:
  • node_id (int) – The node ID to move.
  • x (double) – The x-coordinate of the target point.
  • y (double) – The y-coordinate of the target point.
  • z (double) – The z-coordinate of the target point.
  • normal_flag (int) –
    0 - Allow movement along the surface.
    1 - Allow movement normal to the surface.
  • boundary_flag (int) –
    0 - Allow movement within the boundary.
    1 - Allow movement out of the boundary.
  • midnodes_flag (int) –
    0 - Do not consider neighboring mid-nodes during optimization.
    1 - Consider neighboring mid-nodes during optimization.
Example#
Place the node with ID 102 , use a target point of 10.0 , 5.0 , 0.0 , allow normal movement within the boundary#
import hm
import hm.entities as ent
model = hm.Model()
elems = model.CreateCollectionByDisplayed(ent.Element)
model.elementqualitysetup(elementcollection=elems)
model.elementqualityplacenodenew(node_id=102, x=10.0, y=5.0, z=0.0, normal_flag=1, boundary_flag=0, midnodes_flag=0)
model.elementqualityshutdown(dontsaveflag=1)
