Model.hm_getsolidboundsforsurfaces#
Model.hm_getsolidboundsforsurfaces(surfaces, exclude_solids=1, find_baffles=0)#
Returns a list of bounding surfaces. It can be one list for each set of bounding surfaces found, or nothing if there is not a valid closed bounds found.
Parameters:
  • surfaces (Collection) – The collection containing the input surface entities.
  • exclude_solids (int) – A flag that indicates whether to consider surfaces that already bound solids. Default is exclude_solids=1 if not specified, meaning that algorithm not considers surfaces that already bound solids.
  • find_baffles (int) – A flag that indicates whether to consider baffle/fin surfaces. Default is find_baffles=0 if not specified, meaning that algorithm is not considering baffle surfaces.
Returns:
Example#
Find the solid bounds for surface with ID 100#
import hm
import hm.entities as ent
model = hm.Model()
surface_collection = hm.Collection(model, ent.Surface, [100])
_, resultlist = model.hm_getsolidboundsforsurfaces(surfaces=surface_collection)
for result in resultlist:
    print("Bound Surfaces:", [s.id for s in result.boundingSurfaces])
