Model.adaptive_wrapper_proximity_params#
Model.adaptive_wrapper_proximity_params(self_proximity_for_all, prox_lower_bound, string_array)#
Assigns proximity parameters to the adaptive wrapper mesher. Both local and global proximity controls can be assigned. This function also allows an option for checking self proximity.
This function must be called after Model.adaptive_wrapper_init() and Model.adaptive_wrapper_build().
Parameters:
  • self_proximity_for_all (int) – Global option to check self proximity for all elements. Gaps below this value are considered to be closed.
  • prox_lower_bound (double) – Lower proximity bound for global self proximity check.
  • string_array (hwStringList) –
    The list of parameter strings. Each string should contain one of the following parameters as keywords followed by the parameters values. Keywords and the corresponding values can be separated by a semicolon. Each keyword can be used multiple times to define different groups.
    • WithinGroup: <proximity_lower_bound> <self_proximity_flag> <number_of_comps> <comp_ID1> <comp_ID2> … <comp_IDN>
    Local option to check proximity within specified components. For example, to specify a lower proximity value of 0.5 for comps 11-13: “WithinGroup: 0.5 1 3 11 12 13”
    • AcrossGroups: <proximity_lower_bound> <number_of_comps_in_first_set> <comp1_ID1> <comp1_ID2> … <comp1_IDN> <number of comps in second set> <comp2_ID1> <comp2_ID2> … <comp2_IDN>
    Local option to check proximity between two sets of components. For example, to specify a lower proximity value of 0.5 between comps 10-12 and 20-24: “AcrossGroups: 0.5 3 10 11 12 5 20 21 22 23 24”
Example#
Usage of the adaptive_wrapper_build functions#
import hm
import hm.entities as ent
model = hm.Model()
# Initialization of wrapper mesh with base mesh
elems = hm.Collection(model, ent.Element)
model.adaptive_wrapper_init(collection=elems, clean_intersection=1, wrap_type=0)
# Define features
model.adaptive_wrapper_set_features(
    feature_type=1,
    collection=elems,
    feature_angle=30.0,
    clean_features=1,
    clean_tol=1.0,
# Set various meshing and refinement parameters
model.adaptive_wrapper_set_params(
    max_elem_size=10.0,
    min_elem_size=0.1,
    string_array=[
        "LeakCheckNodes: 20 24 19",
        "GapPatchTolerance: 3.0",
        "HolePatchTolerance: 10.0",
        "RefineByBoxCompIds: 4 5 6",
        "RefineByNodeCurvature: 1",
        "RefineByFeatureProximity: 0",
        "RefineByAllElemSize: 1",
# Proximity options
model.adaptive_wrapper_proximity_params(
    self_proximity_for_all=1,
    prox_lower_bound=0.2,
    string_array=[
        "WithinGroup: 0.5 1 3 10 12 13",
        "WithinGroup: 1.5 3 9 20",
        "AcrossGroup: 0.5 3 10 12 13 4 9 8 7 19",
# Build skeletal octree structure
model.adaptive_wrapper_build()
# Generate mesh
model.adaptive_wrapper_mesh(mesh_type=0, DoRemesh=1, RemeshGrowthRate=1.2)
# End of wrapper mesh
model.adaptive_wrapper_end()
