Model.hm_flangedetectionfindmates#
- Model.hm_flangedetectionfindmates(max_search_dist, min_search_dist, mode=0, percent_mate_area_tol=0., search_scope=0)#
Runs the flange detection mating functions for finding flanges mating ‘groups’. This must be preceded by a call to
Model.hm_flangedetectionfindflanges().max_search_distandmin_search_distare mandatory.All other parameters are optional and have default values. Parameters can be specified in any order.
- Parameters:
max_search_dist (double) – The maximum distance for the proximity search.
min_search_dist (double) – The minimum distance for the proximity search.
mode (int) –
0 - Perform flange-to-flange mating only (default)
1 - Perform flange-to-everything mating
percent_mate_area_tol (double) – The minimum mating area percentage required for valid mating. Default value 0.1.
search_scope (int) – Reserved for future development.
- Returns:
hwReturnStatus- Status object
Example#
Find 2D flanges from elements in all components , use a min width of 2 , a max width of 20 and a feature angle of 20 , and write out all flange details to a file named C:/temp / flanges.txt#import hm import hm.entities as ent model = hm.Model() flangesfile = open("C:/temp/flanges.txt", "w") comps = hm.Collection(model, ent.Component) model.hm_flangedetectioninit(collection=comps) model.hm_flangedetectionsetparams(max_width=20.0, min_width=2.0, feature_angle=20.0) model.hm_flangedetectionfindflanges(find=1) _, result = model.hm_flangedetectiongetnumberofflanges() n=result.numberOfFlanges if n > 0: flangesfile.write(f"Number of flanges = {n}\n") flangesfile.write("Flanges details \n") for i in range(0,n): _, result = model.hm_flangedetectiongetflangedetails(index=i) entityType = result.entityType dimension = result.dimension detectionType = result.detectionType flangeEntityIDs = result.flangeEntityIDs freeBoundaryEntityIDs = result.freeBoundaryEntityIDs connectedBoundaryEntityIDs = result.connectedBoundaryEntityIDs minWidth = result.minWidth maxWidth = result.maxWidth length = result.length hasHoles = result.hasHoles isInfinite = result.isInfinite Details = [ entityType, dimension, detectionType, flangeEntityIDs, freeBoundaryEntityIDs, connectedBoundaryEntityIDs, minWidth, maxWidth, length, hasHoles, isInfinite ] flangesfile.write(f"details = {Details}\n") print(i) status, result = model.hm_flangedetectiongetflangemidline(index=i,offset_distance=5.0) print("pointCoordinates",result.pointCoordinates) Coordinates = result.pointCoordinates for points in Coordinates: midPoint=points.midPoint flangesfile.write(f"midline = {midPoint}\n") model.hm_flangedetectionfindmates(max_search_dist=10.0, min_search_dist=0.0) _, result = model.hm_flangedetectiongetnumberofmatinggroups() m = result.numberOfMatingGroups if m>0: for i in range(0,m): _,result = model.hm_flangedetectiongetmatinggroupdetails(index=i) matingGroupDetails = result.matingGroupDetails for details in matingGroupDetails: memberType = details.memberType memberContents = details.memberContents flangesfile.write(f"memberType = {memberType}\n") flangesfile.write(f"memberContents = {memberContents}\n") else: flangesfile.write("Flange mates not detected.\n") else: flangesfile.write("Flanges not detected.\n") model.hm_flangedetectionend() flangesfile.close()
