Model.morphmanualinit#
Model.morphmanualinit()#
Stores the current node locations for the model so that node movements done through any means (morphing or otherwise) can be recorded and saved as a morph after using the morphmanualapplyenvelope() function.
Manually morphed nodes can later be undone and redone, or saved as a shape.
Example#
Move manually the nodes and apply them to the mesh as if they were handles use internally generated domains with inferred edges , then reject the changes#
import hm
import hm.entities as ent
model = hm.Model()
model.morphmanualinit()
<<any commands which move nodes>>
model.morphmanualapplyenvelope(
    e_collection=hm.Collection(model, ent.Node, [21, 22, 23]),
    f_collection=hm.Collection(model, ent.Element),
    mode=1,
    mbias=1.0,
    fbias=1.0,
    integ=2,
    envelope=0.0,
    undisplayed=0,
model.morphmanualrestore()
