Model.CE_ConnectorCreateAndFERealizeForTrimMass#
Model.CE_ConnectorCreateAndFERealizeForTrimMass(entitycollection, linkentitycollection, ce_rules, ce_le_rule, tolerance, num_ents, config, mass, distribution_type, param1)#
Creates apply mass connectors at the specified location with certain rules, and realize them using a specified config type, mass value and distribution type.
Parameters:
  • entitycollection (Collection) – The collection containing the entities as the location to apply mass connectors. Valid entities are nodes and points.
  • linkentitycollection (Collection) – The collection containing the entities to link. Valid entities are nodes, elements, components and tags.
  • ce_rules (unsigned int) –
    Rule to specify how a link entity is to be added to a connector:
    0 - None
    1 - User selected
    2 - Use name
  • ce_le_rule (unsigned int) –
    Rule that specifies how an entity is to be remembered by the connector:
    0 - None
    1 - User ID
    2 - Use name
  • tolerance (double) – Add entities as links only with in the given tolerance from the specified location.
  • num_ents (int) –
    The number of links.
    -1 - All entities within tolerance will be added as links.
  • config (unsigned int) –
    Apply mass type:
    1100 - Point mass
    1101 - Rigid mass
    1102 - Rigidlink mass
    1103 - rbe3 mass
  • mass (double) – Value of the applied mass.
  • distribution_type (unsigned int) –
    Apply mass distribution type:
    0 - Divide mass by nodes.
    1 - Apply mass to all nodes.
    2 - Divide mass by area.
    3 - Unit area.
  • param1 (unsigned int) – Reserved for future develpment. Must be set to 0.
Example#
Create 2 apply mass connectors at nodes with IDs 1 and 2, using nodes as links, adding nodes as links to the connectors using “proximity” tolerance = 10.0, and setting the remember rule to “none”. Realize connectors using “point mass” (1100), “mass value” = 100.0, distributing the mass to the link nodes using the “divide mass by nodes” method (1)#
import hm
import hm.entities as ent
model = hm.Model()
nodes_collection = hm.Collection(model, ent.Node, [1, 2])
link_nodes = hm.Collection(model, ent.Node, populate=False)
model.CE_ConnectorCreateAndFERealizeForTrimMass(
    entitycollection=nodes_collection,
    linkentitycollection=link_nodes,
    ce_rules=2,
    ce_le_rule=0,
    tolerance=10.0,
    num_ents=-1,
    config=1100,
    mass=100.0,
    distribution_type=1,
    param1=0,
