Model.CE_FE_Absorb#
Model.CE_FE_Absorb(create_flag, curr_solver, num_body_cfgs, body_cfgs, num_head_cfgs, head_cfgs, elem_filter, collection=s_defaultCollection, check_for_material=0, combine=0, conn_at_centernode=0, force_proj=0, link_by_card=0, link_by_interface=0, mcf='', org=0, rul='None', shell_connect='none', t_connect='none', thickness_type=0, tol=0.0, type2_interface=0, weld_cfg_name='', weld_type_num=0, weld_type_name='', area_absorption=0, area_headonly=0, area_in_middle=0, cluster_identify=0, group_links=0, seam_absorption=0, seam_headonly=0, select_special=0, tie_contact=0)#
Absorbs certain FE information into connectors.
Parameters:
  • create_flag (int) –
    0 - Spot connectors
    1 - Seam/area connectors
  • curr_solver (hwString) – The current solver name.
  • num_body_cfgs (int) – The size of the connector body configuration list.
  • body_cfgs (hwString) – The connector body configuration list. Must be enclosed in quotes.
  • num_head_cfgs (int) – The size of the connector head configuration list.
  • head_cfgs (hwString) – The connector head configuration list. Must be enclosed in quotes.
  • elem_filter (hwIntList) – If provided it is indicating to check for specific elements IDs. If it is not provided are used the the displayed elements.
  • collection (Collection) – The collection containing the constraint entities. Should be an empty collection or not be used.
  • check_for_material (int) –
    0 - Do not check for material for mat100 (hexa).
    1 - Check for material for mat100 (hexa).
  • combine (int) –
    0 - Do not combine in case of equivalent body nodes.
    1 - Combine in case of equivalent body nodes.
  • conn_at_centernode (int) –
    0 - Do not enable Connector at Centernode for rbe3 (load transfer).
    1 - Enable Connector at Centernode for rbe3 (load transfer).
  • force_proj (int) –
    0 - Do not enable ACM pattern recognition.
    1 - Enable ACM pattern recognition.
  • link_by_card (int) –
    0 - Do not find link entities by card.
    1 - Find link entities by card.
  • link_by_interface (int) –
    0 - Do not find link entities by interface.
    1 - Find link entities by interface.
  • mcf (hwString) – The file name for the main connection file.
  • org (int) –
    0 - Use current component
    1 - Move connectors to FE component
  • rul (hwString) – The re-connect rule. Valid values are None, User id or User name.
  • shell_connect (hwString) – Valid values are body, head, projs, or none.
  • t_connect (hwString) – Valid values are body, head, projs, or none.
  • thickness_type (int) –
    The spot connector thickness type:
    1 - equival (T1+T2)/2.
    3 - shell gap.
    5 - const thickness.
  • tol (double) – The maximum distance allowed between the connector and each of its links.
  • type2_interface (int) –
    0 - Do not find link entities by interface for type2 (spring).
    1 - Find link entities by interface for type2 (spring).
  • weld_cfg_name (hwString) – The type of FE realization that needs to be converted to connectors.
  • weld_type_num (int) – The selected weld type ID.
  • weld_type_name (hwString) – The selected weld type name.
  • area_absorption (int) –
    0 - Do not absorb as area.
    1 - Absorb as area if possible.
  • area_headonly (int) –
    0 - Do not only absorb FE with heads as area.
    1 - Only absorb FE with heads as area.
  • area_in_middle (int) –
    0 - Do not move area to the middle position.
    1 - Move area to the middle position.
  • cluster_identify (int) –
    0 - Do not absorb single element cluster as area.
    1 - Absorb single element cluster as area.
  • group_links (int) –
    0 - Do not organize the links into two groups.
    1 - Organize the links into two groups.
  • seam_absorption (int) –
    0 - Do not absorb as seam.
    1 - Absorb as seam if possible.
  • seam_headonly (int) –
    0 - Do not only absorb FE with heads as seam.
    1 - Only absorb FE with heads as seam.
  • select_special (int) –
    0 - Do not enable enhanced approach.
    1 - Enable enhanced approach.
  • tie_contact (int) –
    0 - Do not enable With tie contact.
    1 - Enable With tie contact.
Examples#
Absorb spot connectors in specific elements in LS-DYNA profile#
    import hm
    import hm.entities as ent
    model = hm.Model()
    collection = hm.Collection(model, ent.Constraint, populate=False)
    elem_filter = [ 345, 346, 347, 348, 353, 354, 355, 356, 365, 366, 367, 368,\
                    11572211, 11572251, 11572253, 11572256, 11572257, 11572258,\
                    11572259, 11572260, 11572261, 11572262, 11572263, 11572264,\
                    11572512, 11572555, 11572573, 11572719, 11572780, 11572881,\
                    11572905, 11573361, 11573362, 18018894, 18018895, 18019681,\
                    18019756, 18021150, 18021590, 18021605, 18021606, 18021703,\
                    18021705, 18022153, 18022154, 18022155, 18022278, 18022285,\
                    18022315, 18022649, 18024271, 18024272, 18024273, 18024311,\
                    18024312, 18024320, 18024343, 18024344, 18024347, 18024348,\
                    18024351, 18024352, 18024356, 18024380, 18024831, 18026501,\
    model.CE_FE_Absorb(
        create_flag=0,
        curr_solver="lsdyna",
        num_body_cfgs=2,
        body_cfgs="208 206",
        num_head_cfgs=0,
        head_cfgs="contact",
        elem_filter=elem_filter,
        combine=0,
        org=0,
        rul="User id",
        weld_cfg_name="custom",
        weld_type_num=152,
        weld_type_name="Hexa (Contact)",
        group_links=0,
        collection=collection,
Absorb seam connectors in Nastran profile#
    import hm
    model = hm.Model()
    model.CE_FE_Absorb(
        create_flag=1,
        curr_solver="nastran",
        num_body_cfgs=2,
        num_head_cfgs=0,
        org=0,
        rul="None",
        seam_absorption=1,
        seam_headonly=1,
        area_absorption=0,
        area_headonly=0,
        area_in_middle=1,
        cluster_identify=0,
        tol=20.0,
        group_links=0,
