Model.CE_AutoCreateAreaConnectors#
Model.CE_AutoCreateAreaConnectors(inputCollection, searchTolerance, shellThicknessOption=0, shellThicknessValue=0.0)#
This command automatically creates area connectors by identifying pairs of penetrating entities within a given search tolerance and feature angle (uses the global feature angle set by the user).
Parameters:
  • inputCollection (Collection) – The collection containing the input entities. Valid entity types are parts and components.
  • searchTolerance (double) – The search tolerance used for finding pairs of penetrating entities to create area connectors.
  • shellThicknessOption (int) –
    The option to determine the use of shellthicknessvalue to calculate search tolerance.
    0 - shellthicknessvalue is not considered
    1 - shellthicknessvalue will be added to the thickness of shell elements
    2 - shellthicknessvalue specifies a multiplication factor for shell elements
  • shellThicknessValue (double) – Based on the shellthicknessvalueoption value, this is either an add-on value or a multiplication factor for shell thicknesses during proximity detection.
Example#
Automatically create area connectors on all components within search tolerance of 10.0#
import hm
import hm.entities as ent
model = hm.Model()
all_comps = hm.Collection(model, ent.Component)
model.CE_AutoCreateAreaConnectors(
    inputCollection=all_comps,
    searchTolerance=10.0
Automatically create area connectors on displayed parts with 20.0 search tolerance#
import hm
model = hm.Model()
displayed_parts = hm.CollectionByDisplayed(model, ent.Part)
    inputCollection=displayed_parts,
    searchTolerance=20.0
Automatically create area connectors on displayed parts by considering shell thickness value and an add-on of 1.0#
import hm
model = hm.Model()
    searchTolerance=1.0,
    shellThicknessOption=1,
    shellThicknessValue=1.0
Automatically create area connectors on displayed components by considering shell thickness value and a multiplication factor of 2.5#
import hm
model = hm.Model()
displayed_comps = hm.CollectionByDisplayed(model, ent.Component)
    inputCollection=displayed_comps,
    shellThicknessOption=2,
    shellThicknessValue=2.5
