Model.fill_circular_holes#
Model.fill_circular_holes(collection, radius_limit)#
This function is used to fill flat circular holes on 2D elements.
Parameters:
  • collection (Collection) – The collection containing the node entities on the holes to be filled.
  • radius_limit (double) – The radius limit for holes to be filled. If set to a positive value, then all circular flat holes with radius less than this limit are filled. In this case, collection can be set to 0 and is ignored. Otherwise, all flat holes containing nodes marked are filled.
Examples#
Fill the hole containing node with ID 7989#
import hm
import hm.entities as ent
model = hm.Model()
model.fill_circular_holes(
    collection=hm.Collection(model,ent.Node, [7989]), radius_limit=-1.0
Fill the holes with a radius less than 5.0#
import hm
model = hm.Model()
    collection=hm.Collection(model,ent.Node), radius_limit=5.0
