Model.positionentity_bycollection#
Model.positionentity_bycollection(collection, source_coords=hwTripleList(), target_coords=hwTripleList(), source_nodes=s_defaultEntityList, target_nodes=s_defaultEntityList)#
Positions selected entities in space. You can specify a collection of special points either by providing lists of coordinates or a list of node entities.
Parameters:
  • collection (Collection) – The collection containing the entities to modify.
  • source_coords (hwTripleList) – The list of lists of x, y, z coordinates for source points.
  • target_coords (hwTripleList) – The list of lists of x, y, z coordinates for target points.
  • source_nodes (EntityList) – The list of source node entities.
  • target_nodes (EntityList) – The list of target node entities.
Examples#
Position the components with IDs 41 , 42 use source and target coordinates ( case 1 )#
import hm
import hm.entities as ent
model = hm.Model()
model.positionentity(
    collection=hm.Collection(model,ent.Component,[41, 42]),
    source_coords=[
        [1268.2080057472, 1390.3206502704, 261.94218701528],
        [1453.2078889448, 1211.6243689829, 214.0606603456],
        [1268.2079790993, 1032.9281037002, 166.17913259364],
    target_coords=[
        [83.410371153542, 206.5, 174.00000024836],
        [268.41037026165, 206.5, -10.999999839969],
        [83.410373806586, 206.5 - 196.00000026844],
Position the components with IDs 41 , 42 use source and target coordinates ( case 2 )#
import hm
model = hm.Model()
    source_coords=[
    target_coords=[
Position the components with IDs 41 , 42 use source and target coordinates ( case 3 )#
import hm
model = hm.Model()
    source_coords=[1268.2080057472, 1390.3206502704, 261.94218701528],
    target_coords=[83.410371153542, 206.5, 174.00000024836],
Position the components with IDs 41 , 42 use source nodes and target nodes ( case 1 )#
import hm
model = hm.Model()
    source_nodes=[
        ent.Node(model, 221417),
        ent.Node(model, 221416),
        ent.Node(model, 221415),
    target_nodes=[
        ent.Node(model, 221414),
        ent.Node(model, 221413),
        ent.Node(model, 221412),
Position the components with IDs 41 , 42 use source nodes and target nodes ( case 2 )#
import hm
model = hm.Model()
    source_nodes=[
    target_nodes=[
Position the components with IDs 41 , 42 use source nodes and target nodes ( case 3 )#
import hm
model = hm.Model()
    source_nodes=[
    target_nodes=[
