Model.CE_CreateNodeOnSeamConnector#
Model.CE_CreateNodeOnSeamConnector(collection, x=0, y=0, z=0)#
Creates a node on a seam connector at a given position. This node can then be used to trim the seam connector at that location. To create a node with a mouse click on a connector, the x, y, and z values should all be passed as -1.
Parameters:
  • collection (Collection) – The collection containing the seam connector entities to trim.
  • x (double) – The x position on the seam connector.
  • y (double) – The y position on the seam connector.
  • z (double) – The z position on the seam connector.
Examples#
Create a temp node on seam connector with ID 101 at (100.0, 50.0, 50.0)#
import hm
import hm.entities as ent
model = hm.Model()
model.CE_CreateNodeOnSeamConnector(
    collection=hm.Collection(model, ent.Connector, [101]), x=100.0, y=50.0, z=50.0
Create a temp node on seam connector with ID 101 at a mouse click position#
import hm
model = hm.Model()
    collection=hm.Collection(model, ent.Connector, [101]), x=-1, y=-1, z=-1
