Model.endnotehistorystate#
- Model.endnotehistorystate(name)#
Defines the end of a history state. Must be preceded by a call to
Model.startnotehistorystate()with the same name value.This function is used to group a set of functions into a single undo/redo operation. All functions that appear within the start/end block must be supported for undo/redo.
- Parameters:
name (hwString) – The name of the history state. If the name contains spaces, it must be enclosed in curly braces or quotes.
Example#
Execute an element remesh operation on two selections of elements , but consider them as a single history operation#import hm import hm.entities as ent model = hm.Model() model.startnotehistorystate(name="Remesh two element selections") model.setedgedensitylinkwithaspectratio(aspectratio=0) hm.setoption(element_order=1) model.setusefeatures(mode=3) elems1 = hm.Collection(model, ent.Element, list(range(1,101))) model.defaultremeshelems( collection=elems1, elem_size=1.0, elem_type=2, elem_type_2=2, comp_mode=1, size_control=1, skew_control=1, edge_mesh_type=1, min_size=0.0, max_size=0.0, max_deviation=0.0, max_angle=0.0, previous_settings=2, vertex_angle=30.0 ) elems2 = hm.Collection(model, ent.Element, list(range(1,201))) model.defaultremeshelems( collection=elems2, elem_size=2.0, elem_type=2, elem_type_2=2, comp_mode=1, size_control=1, skew_control=1, edge_mesh_type=1, min_size=0.0, max_size=0.0, max_deviation=0.0, max_angle=0.0, previous_settings=2, vertex_angle=30.0 ) model.setusefeatures(mode=0) model.endnotehistorystate(name="Remesh two element selections")
