Model.smoothelements#
Model.smoothelements(faceindex, smoothmethod, iterations)#
In the automeshing module, applies the specified smoothing operator to the mesh (if any) found on the face for the given number of times.
Parameters:
  • faceindex (unsigned int) – The index of the face into the particular surface under consideration.
  • smoothmethod (int) –
    The smoothing method to use. Valid values are:
    0 - autodecide
    1 - size corrected
    2 - shape corrected
  • iterations (int) – The number of times to apply the element smoothing operator.
Example#
Smoothen the elements of the mesh of the first face of the surface twenty - five times , use whichever algorithm the automeshing module determines is proper#
import hm
import hm.entities as ent
model = hm.Model()
model.smoothelements(faceindex=1, smoothmethod=0, iterations=25)
