Model.hm_getmodelcheckcheckresult#
Model.hm_getmodelcheckcheckresult(check_display_name)#
Returns the result for a given check.
Parameters:
check_display_name (hwString) – The GUI display name of the check. This is case sensitive.
Returns:
  • hwReturnStatus - Status object
  • HmQueryResult - Result object containing the output values:
    • status (bool) - True if check is run and false otherwise
    • numberOfFailedEntities (int) - The count of failed entities
    • entityIdList (numpy.ndarray) - The IDs of the failed entities
Example#
Get the result for the “ Unused materials “ check#
import hm
import hm.entities as ent
model = hm.Model()
_, result = model.hm_getmodelcheckcheckresult(
    check_display_name="Unused materials"
print("status:", result.status)
print("stanumberOfFailedEntitiestus:", result.numberOfFailedEntities)
print("entityIdList:", result.entityIdList)
