Model.includesuppressoutput#
Model.includesuppressoutput(include_id, include_shortname, state)#
Sets the export/do not export state of all supported entities contained within the include file (but not the include file itself) with include_id and include_shortname. Only one of these two options need to be specified, however include_id will take precedence if specified.
The state argument indicates the export/do not export status for the supported entities contained in the include. If state=0 indicates to set the entities to “export”. If state=1 indicates to set the entities to “do not export”.
Include files do not have an export/do not export state that is controlled by this function. Instead use the function Model.updateincludedata2().
Parameters:
  • include_id (unsigned int) – The ID of the include file.
  • include_shortname (hwString) – The name of the include file.
  • state (int) –
    The state argument indicates the active/inactive status for the supported entities contained in the include.
    0 - Indicates to set the entities to “export”.
    1 - Indicates to set the entities to “do not export”.
Examples#
Set all supported entities contained within include file ID 5 to “ export “#
import hm
import hm.entities as ent
model = hm.Model()
model.includesuppressoutput(include_id=5, include_shortname="", state=0)
Set all supported entities contained within include file shortname “ include.txt “ to “ do not export “#
import hm
model = hm.Model()
model.includesuppressoutput(include_id=None, include_shortname="include.txt", state=1)
