Model.nodeplaceatxyz#
Model.nodeplaceatxyz(node, surface, x, y, z)#
Moves a node to a location on a surface and associates the node to the surface.
Parameters:
  • node (Entity) – The object describing the node entity to be moved.
  • surface (Entity) – The object describing the surface entity to which the node should be associated.
  • x (double) – The x component of the point on the surface where the node is to be removed.
  • y (double) – The y component of the point on the surface where the node is to be removed.
  • z (double) – The z component of the point on the surface where the node is to be removed.
Example#
Move the node with ID 115 to the surface with ID 1 at location ( 75,30,86 )#
import hm
import hm.entities as ent
model = hm.Model()
model.nodeplaceatxyz(
    node=ent.Node(model, 115),
    surface=ent.Surface(model, 1),
    x=75.0,
    y=30.0,
    z=86.0,
