Model.hm_collisionwriteresultsfile#
- Model.hm_collisionwriteresultsfile(filename, include_ignored=False)#
Writes the current collision results to a file. This must be preceded by a call to relevant hm_collision functions to generate the collision data. In addition, the
pair_resultsflag tohm_collisioncheck()must be set toTrue.- Parameters:
filename (hwString) – The full name and path of the file to write the results to.
include_ignored (bool) –
Specifies if results ignored when the
allowable_depthvalue is specified viaModel.hm_collisioninit()should be reported or not:0 - Do not include ignored results (default).
1 - Include ignored results.
Add a value of 10 to each of these to append to an existing file. By default, the file is overwritten.
- Returns:
hwReturnStatus- Status object
Example#
Find intersect surfaces from IDs 1 - 10 and write the results to the file * C:/collision.txt *#import hm import hm.entities as ent model = hm.Model() checking_surfs = hm.Collection(model, ent.Surface, list(range(1, 11))) intersect_surfs = hm.Collection(model, ent.Surface, populate=False) model.hm_collisioninit() model.hm_collisionentitycreate( collection=checking_surfs, dimension=0, thickness_type=1, thickness=0, edge_penetration=0, midside_nodes=0, split_quads=0, used_topology=0, grouping_identifier=False, offset=0, ) model.hm_collisioncheck(intersected_surfaces=intersect_surfs, pair_result=True) model.hm_collisionwriteresultsfile(filename="C:/collision.txt") model.hm_collisionend()
