Model.hm_encodeshape#
- Model.hm_encodeshape(entity_collection, encoding_algorithm=0, sphhar_bandwidth=16, sphhar_falloff=2.828427, sphhar_radii=32, sphhar_resolution=64)#
Generates an encoded string representing the shape of a geometry.
- Parameters:
entity_collection (Collection) – The collection containing the input entities to generate the encoding for. Valid entities are surfaces and elements.
encoding_algorithm (int) –
The optional encoding algorithm to use. Valid values are:
0 - sphhar technique (default)
sphhar_bandwidth (int) – Optional, valid for
encoding_algorithm0. (default=16)sphhar_falloff (double) – Optional, valid for
encoding_algorithm0. (default=2.828427)sphhar_radii (int) – Optional, valid for
encoding_algorithm0. (default=32)sphhar_resolution (int) – Optional, valid for
encoding_algorithm0. (default=64)
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:encoding (numpy.ndarray)
Example#
Calculate and diff the encodings from all surfaces against all elements#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_encodeshape(entity_collection=hm.Collection(model, ent.Surface)) x = result.encoding print("encoding_1", x) _, result = model.hm_encodeshape(entity_collection=hm.Collection(model, ent.Element)) y = result.encoding print("encoding_2", y) _, result = model.hm_diffencodings(encodings1=x, encodings2=y) print("distance", result.distance)
