Model.beamsectionsetdatastandard#
- Model.beamsectionsetdatastandard(parameter_array, beam_sect_id, beam_sect_type, orientation_angle, beam_sect_subtype)#
Updating a shell beam section requires two functions of which this is the second. This function will update all data for a shell type beam section. The function
Model.beamsectionsetdataroot()should precede use of this function.Beam section data cannot be updated piecemeal with this function; all data must be known for the beam and sent in as arguments.
Results will be calculated for the beam section automatically after updating.
- Parameters:
parameter_array (hwDoubleList) –
The ID of the double array that contains the standard section parameters.
The contents of this array are stored in threes with one group of three for each parameter. The first three values are the initial, minimum, and maximum values for the first parameter, such as the height, in that order. The second three values are the initial, minimum, and maximum values for the second parameter, such as the length. This repeats for all parameters. See the table below for a list of the number of parameters and descriptions of them for each section, solver, and subtype.
The terms height, width, top, bottom, vertical, horizontal, left and right refer to the directions when viewing the section, such that the y-axis is pointing upward and the z-axis is pointing to the right. If the beam section type can have multiple orientation angles, the terms apply to the zero degree case.
Section Type # of Param Parameter values (at zero or default angle) Analysis code Section subtype Box 0 3 1: Thickness
2: Height
3: WidthHyperMesh HMBox 4 1: Thickness (top and bottom)
2: Height
3: Width
4: Thickness (left and right)Rad/OS/Nas
LS-DYNA
PermasBox
Tubular Box
Type3
PROFIL_76 1: Thickness (bottom)
2: Height
3: Width
4: Thickness (left)
5: Thickness (top)
6: Thickness (right)Rad/OS/Nas
Ansys
LS-DYNA
Abaqus
Box1
HREC
Box-shape1
BOXGeneral Symmetric 1 8 1: Thickness
2: A/T
3: J/T
4: Iyy/T
5: Izz/T
6: Width
7: Height
8: Bredt AreaHyperMesh HMGensym General Asymmetric 2 9 1: Thickness
2: A/T
3: J/T
4: Iyy/T
5: Izz/T
6: Stress Recovery Y
7: Stress Recovery Z
8: Bredt Area
9: Iyz/THyperMesh HMGennonsym Constant Perimeter Box 3 3 1: Thickness
2: Width & Height
3: PerimeterHyperMesh HMCpbox Hat 4 4 1: Width
2: Thickness
3: Height (without flanges)
4: Flange lengthHyperMesh
LS-DYNAHMHat
Hat-shape1: Height
2: Thickness
4: Flange lengthRad/OS/Nas HAT 9 1: Width
2: Leg thickness (top)
4: Flange length (bottom)
5: Flange thickness (bottom)
6: Arch thickness
7: Flange thickness (top)
8: Flange length (top)
9: Leg Thickness (bottom)ANSYS HATS Tube 7 2 1: Inner radius
2: Outer radiusHyperMesh
Rad/OS/Nas
ANSYS
Abaqus
LS-DYNA
PermasHMTube
Tube
CTUBE
PIPE
Tubular
Type2
PROFIL_9Rectangle 10 2 1: Height
2: WidthHyperMesh
ANSYS
Abaqus
LS-DYNAHMRect
RECT
RECT
Solid box
PROFIL_61: Width
2: HeightRad/OS/Nas Bar Circle 11 1 1: Radius HyperMesh
Rad/OS/Nas
ANSYS
Abaqus
LS-DYNAHMCirc
Rod
CSOLID
CIRC
Circular
PROFIL_8I-Section 12 4 1: Total width (flange)
2: Total height (web)
3: Web thickness
4: Flange lengthLS-DYNA I-shape 6 1: Total width (web)
2: Flange width (left)
3: Flange width (right)
4: Web thickness
5: Flange thickness (left)
6: Flange thickness (right)HyperMesh
ANSYS
Abaqus
LS-DYNA
LS-DYNAHMIsec
I
I
I-shape1
I-shape2
PROFIL_1B1: Total width (web)
2: Flange width (bottom)
3: Flange width (top)
4: Web thickness
6: Flange thickness (top)Rad/OS/Nas I Channel 13 4 1: Leg length
2: Base length
3: Base thickness
4: Leg thickness (both)HyperMesh
Rad/OS/Nas
Rad/OS/Nas
Rad/OS/Nas
LS-DYNA
LS-DYNA
LS-DYNAHMChan
Chan
Chan1
Chan2
Channel
Channel1
Channel2
PROFIL_26 1: Base length
2: Leg length (right)
3: Leg length (left)
4: Leg thickness (right)
5: Leg thickness (left)
6: Base thicknessANSYS CHAN L-section 14 4 1: Leg length (height)
2: Base length (width)
3: Leg thickness (vertical)
4: Base thickness (horizontal)HyperMesh
Rad/OS/Nas
ANSYS
Abaqus
LS-DYNAHMLsec
L
L
L
L-shape
PROFIL_3
PROFIL_3BT-section 15 4 1: Flange length (total)
2: Web length + flange thickness
3: Flange thickness
4: Web thicknessHyperMesh
Rad/OS/Nas
Rad/OS/Nas
Rad/OS/Nas
ANSYS
Abaqus
LS-DYNA
LS-DYNA
LS-DYNAHMTsec
T
T1
T2
T
T
T-shape
T-shape1
T-shape2
PROFIL_5H-section 16 4 1: Web height (excluding flanges)
2: Flange thickness (each)
3: Flange thickness (total)
4: Web thicknesHyperMesh
Rad/OS/Nas
Rad/OS/Nas
LS-DYNAHMHsec
H
I1
H-shape
PROFIL_1Asymmetric 17 4 1: Base length (total)
2: One leg length + base thickness
3: Base thickness
4: Leg thickness (each)Rad/OS/Nas Z
PROFIL_4
PROFIL_4B6 1: Base length (total)
2: Leg length (right/down)
3: Leg length (left/up)
4: Leg thickness (right/down)
5: Leg thickness (left/up)
6: Base thicknessANSYS Z 8 1: Total width (web)
2: Total flange length (left)
3: Total flange length (right)
4: Web thickness
7: Flange offset (left)
8: Flange offset (right)Permas Type1 Cross 18 4 1: Leg length (horizontal - exclude web)
2: Web thickness (vertical)
3: Total web length (vertical)
4: Leg thickness (horizontal)Rad/OS/Nas
LS-DYNACross
CrossTrapezoid 19 3 1: Altitude (horizontal)
2: Base length (left)
3: Base length (right)Abaqus TRAPEZOID beam_sect_id (unsigned int) – The beam section ID to update.
beam_sect_type (int) –
Standard beam section type. Valid values are:
0 - Thin walled box section
1 - Generic symmetric section
2 - Generic non-symmetric section
3 - Constant perimeter box section
4 - Hat section
7 - Tube section
10 - Rectangle section
11 - Circle section
12 - Symmetric I-section
13 - Channel section
14 - L-section
15 - T-section
16 - H-section
17 - Asymmetric section
18 - Cross section
19 - Trapezoid section
Not all section types are supported for all solvers. Consult the beam_sect_subtype table below.
orientation_angle (int) –
Angle of rotation for the standard section. Valid values are:
0 - 0 degrees.
1 - 90 degrees.
2 - 180 degrees.
3 - 270 degrees.
Section Type HyperMesh OptiStruct Nastran ANSYS Abaqus LS-DYNA Permas Box 0 0 0 0 0 0 0 General Symmetric 1 0 --- --- --- --- --- General Asymmetric 2 0 --- --- --- --- --- Constant Perimeter Box 3 0 --- --- --- --- --- Hat 4 0 270 0 --- 0 --- Tube 7 0 0 0 0 0 0 Rectangle 10 0 90 0 0 0 --- Circle 11 0 0 0 0 0 --- I-Section 12 0 270 0 0 0 --- Channel 13 0 0 (chan2)
90 (chan)
90 (chan1)0 --- 0 (Channel)
0 (Channel1)
90 (Channel2)--- L-Section 14 0 0 0 0 0 --- T-Section 15 0 0 (T1)
90 (T2)
270 (T)180 0 0 (T-shape)
90 (T-shape1)
180 (T-shape2)--- H-Section 16 0 0 (I1)
90 (H)--- --- 0 --- Asymmetric 17 --- 90 0 --- 0 0 Cross 18 --- 0 --- --- 0 --- Trapezoid 19 --- --- --- 0 --- --- Note
Not all angles are supported for all beam sections for all Solvers. Consult the table below. The angles are shown where they differ for the full list of supported types.
beam_sect_subtype (hwString) –
The name of the section subtype. Consult the table below for supported values for each Solver and section type.
Section Type HyperMesh OptiStruct Nastran ANSYS Abaqus LS-DYNA Permas Box 0 HMBox Box
Box1HREC BOX Box-shape1
Tubular boxType3 General Symmetric 1 HMGensym --- --- --- --- --- General Asymmetric 2 HMGennonsym --- --- --- --- --- Constant Perimeter Box 3 HMCpbox --- --- --- --- --- Hat 4 HMHat HAT HATS --- Hat-shape --- Tube 7 HMTube Tube CTUBE PIPE Tubular Type2 Rectangle 10 HMRect Bar RECT RECT Solid box --- Circle 11 HMCirc Rod CSOLID CIRC Circular --- I-Section 12 HMIsec I I I I-shape
I-shape1
I-shape2--- Channel 13 HMChan Chan
Chan1
Chan2CHAN --- Channel
Channel1
Channel2--- L-Section 14 HMLsec L L L L-shape --- T-Section 15 HMTsec T1
T2
TT T T-shape
T-shape1
T-shape2--- H-Section 16 HMHsec H
11--- --- H-shape --- Asymmetric 17 --- Z Z --- --- Type1 Cross 18 --- Cross --- --- Cross --- Trapezoid 19 --- --- --- TRAPEZOID --- ---
Update the parameter data for a standard hat section with ID 1. Note that this function should be used in tandem withModel.beamsectionsetdatastandard()as follows#import hm model = hm.Model() model.beamsectionsetdataroot( beam_sect_id=1, collector_id=1, solver=0, beam_config=2, line_color=7, fill_color=1, flags=0, torsion_factor=1, warping_factor=1, orient_vector1=0, orient_vector2=0, orient_origin1=0, orient_origin2=0 ) model.beamsectionsetdatastandard( parameter_array=[6.0, 6.0, 6.0, 0.5, 0.5, 0.5, 4.0, 4.0, 4.0, 1.0, 1.0, 1.0], beam_sect_id=1, beam_sect_type=4, orientation_angle=0, beam_sect_subtype="HMHat" )
