Model.midsurface_remove_target#
- Model.midsurface_remove_target(face, offsetpoint_x, offsetpoint_y, offsetpoint_z, point_sel_code)#
Finds the surface vertex that is closest to a chosen point and, if it is close enough, removes targets from this vertex.
- Parameters:
face (Entity) – The index of the surface to offset.
offsetpoint_x (double) – The x-coordinate of a point near the desired vertex.
offsetpoint_y (double) – The y-coordinate of a point near the desired vertex.
offsetpoint_z (double) – The z-coordinate of a point near the desired vertex.
point_sel_code (int) – This argument is not currently used, please set it
point_sel_code=0.
Note
You cannot manually employ this function, because HyperMesh must internally generate the index values (they cannot simply be typed in).
