Model.hm_getsolver#
Model.hm_getsolver(value='name')#
Returns the name or ID of the solver as provided by the template. If no name is provided, or no template is loaded, "none" is returned.
Parameters:
value (hwString) –
An optional argument that specifies the type of value to return. Valid values:
id - Return the template ID
name - Return the template name (default)
Returns:
  • hwReturnStatus - Status object
  • HmQueryResult - Result object containing the output values:
    • Keys valid for value="id"
      • solver (int) - The ID of the solver as provided by the template.
    • Keys valid for value="name"
      • solver (str) - The name of the solver as provided by the template.
Examples#
Get the ID of the current solver template#
import hm
import hm.entities as ent
model = hm.Model()
_, result = model.hm_getsolver(value="id")
print("Solver Template ID:", result.solver)
Get the name of the current solver template#
import hm
model = hm.Model()
_, result = model.hm_getsolver()
print("Solver Template Name:", result.solver)
