Model.createweldsbetweenelemsusingpoints#
Model.createweldsbetweenelemsusingpoints(elem1_collection, elem2_collection, single_col, point_collection, tol, syst, configval, property, remesh)#
Creates weld element(s) between pre-existing elements at the given point(s).
Parameters:
  • elem1_collection (Collection) – The collection containing the element entities for the first element collector.
  • elem2_collection (Collection) – The collection containing the element entities for the second element collector, if given.
  • single_col (int) –
    Flag for the number of element collectors used:
    1 - One elem collector.
    0 - Two elem collectors.
  • point_collection (Collection) – The collection containing the point entities.
  • tol (double) – The maximum distance allowed between the point (from the point collection) and the element (from the elem collections) to weld this element.
  • syst (int) –
    Systems flag:
    1 - Build systems.
    0 - Do NOT build systems.
  • configval (int) –
    Weld element type created:
    2 - plot
    3 - weld
    5 - rigid
    21 - spring
    60 - bar
    61 - rod
    70 - gap
  • property (hwString) – Name of the property collector. Used to retrieve the property ID.
  • remesh (int) – Remesh flag (always zero).
Example#
Each of the three points on the mark (16, 17, and 18) try to project normally onto as many elements as they can that are within a tolerance of 1.0. All of the non-adjacent elements found for each point’s projections are then welded together at their projection points#
import hm
import hm.entities as ent
model = hm.Model()
elems1 = hm.Collection(model, ent.Element, populate=True)
elems2 = hm.Collection(model, ent.Element, populate=False)
points = hm.Collection(model, ent.Point, populate=True)
model.createweldsbetweenelemsusingnodes(
    elem1_collection=elems1,
    elem2_collection=elems2,
    single_col=1,
    point_collection=points,
    tol=1.0,
    syst=1,
    configval=3,
    property="myprop",
    remesh=0,
