Model.adjustgroupsnormal#
Model.adjustgroupsnormal(name, main_flag, collection, elem_flag, orientation_element, reverse_normal)#
Adjusts a group normal using an orientation element.
Parameters:
  • name (hwString) – The name of the group entity to adjust. User can directly supply a Python string.
  • main_flag (int) –
    0 - Use secondary
    1 - Use main
  • collection (Collection) – The collection containing the elements to adjust.
  • elem_flag (int) –
    Flag for reversing the contact normal of all or individual elements of the group.
    0 - All elements, collection is ignored
    1 - Individual elements, collection is used
  • orientation_element (unsigned int) – The ID of the shell element that should be used for shell group normal correction on shell face. This element should be part of the selection.
  • reverse_normal (int) –
    0 - Correct group normal along the direction of orientation_element normal
    1 - Correct group normal opposite to the direction of orientation_element normal
Examples#
Reverse the normal of all main elements of the group “ test “#
import hm
import hm.entities as ent
model = hm.Model()
model.adjustgroupsnormal(
    name="test",
    main_flag=1,
    collection=hm.Collection(model,ent.Element,populate=False),
    elem_flag=0,
    orientation_element=0,
    reverse_normal=0
Reverse the normal of all secondary elements of the group “ test “#
import hm
model = hm.Model()
    name="test",
    main_flag=0,
    elem_flag=0,
    reverse_normal=0
Adjust the normal of group “ test “ for the elements with IDs 12 , 23 , 29 , and 53 in the normal direction of reference element with ID 23#
import hm
model = hm.Model()
elems = hm.Collection(model, ent.Element, [12,23,29,53])
    name="test",
    main_flag=1,
    collection=elems,
    elem_flag=1,
    orientation_element=23,
    reverse_normal=0
Adjust the normal of group “ test “ for the elements with ID 12 , 23 , 29 , and 53 in the reverse normal direction of reference element with ID 23#
import hm
model = hm.Model()
    name="test",
    main_flag=1,
    collection=elems,
    elem_flag=1,
    reverse_normal=1
