Model.createweldsbetweenelemsusingnodes#
Model.createweldsbetweenelemsusingnodes(elem1_collection, elem2_collection, single_col, node_collection, tol, syst, configval, property, remesh)#
Creates weld element(s) between pre-existing elements at the given node(s).
Parameters:
  • elem1_collection (Collection) – The collection containing the element entities for the first element collector.
  • elem2_collection (Collection) – The collection containing the element entities for the second element collector, if given.for the second comp collector, if given.
  • single_col (int) –
    Flag for the number of element collectors used:
    1 - One element collector.
    0 - Two element collectors.
  • node_collection (Collection) – The collection containing the node entities.
  • tol (double) – The maximum distance allowed between the node (from the node collection) and the element (from the element collection) to weld this element.
  • syst (int) –
    Systems flag:
    1 - Build systems.
    0 - Do NOT build systems.
  • configval (int) –
    Type of weld element created:
    2 - plot
    3 - weld
    5 - rigid
    21 - spring
    60 - bar
    61 - rod
    70 - gap
  • property (hwString) – Name of the property collector. Used to retrieve the property ID.
  • remesh (int) – Remesh flag (always 0).
Example#
Each of the three nodes on the collection with IDs (16, 17, and 18) try to project normally onto as many elements as they can that are within a tolerance of 1.0. All of the non-adjacent elements found for each node’s projections are then welded together at their projection points#
import hm
import hm.entities as ent
model = hm.Model()
elems1 = hm.Collection(model, ent.Element, populate=True)
elems2 = hm.Collection(model, ent.Element, populate=False)
nodes = hm.Collection(model, ent.Node, [16, 17, 18])
model.createweldsbetweenelemsusingnodes(
    elem1_collection=elems1,
    elem2_collection=elems2,
    single_col=1,
    node_collection=nodes,
    tol=1.0,
    syst=1,
    configval=3,
    property="myprop",
    remesh=0,
