Model.elementtestskew#
Model.elementtestskew(collection, skewangle, outputcollection, dimension, contour, title)#
Tests 2D and 3D elements for whether or not they pass the skew element quality check, and puts those that fail on the specified outputcollection.
Parameters:
  • collection (Collection) – The collection containing the element entities to test.
  • skewangle (double) – The value to use as a threshold beyond which elements should be considered to have failed the test (in degrees).
  • outputcollection (Collection) – The collection containing the failed element entities.
  • dimension (int) –
    A code telling to measure the dimension of:
    2 - Measure 2D elements.
    4 - Measure 3D elements.
  • contour (int) –
    A code telling if should:
    0 - Display the results of the test normally.
    1 - Display the elements color coded by their ratings.
    2 - Build a histogram showing the distribution of ratings.
  • title (hwString) – The title to label the curve in the histogram.
Example#
Testing all displayed 3D elements for a skew value less than 60#
import hm
import hm.entities as ent
model = hm.Model()
elems1 = model.CreateCollectionByDisplayed(ent.Element)
elems2 = hm.Collection(model, hm.FilterByEnumeration(ent.Element, ids=hm.hwUIntList([])))
model.elementtestskew(
    collection=elems1,
    skewangle=60,
    outputcollection=elems2,
    dimension=2,
    contour=0,
    title="2D Element Skew"
Note
The details of the skew element quality check can be found in the online help for the Check Elements panel.
