Model.feoutput_singleinclude#
Model.feoutput_singleinclude(id, shortname, export_template, filename, reserved1, reserved2, export_type, string_array=s_defaultStringList)#
Creates an export file based on an output template, for a single include file.
Parameters:
  • id (unsigned int) – The ID of the include to export. If shortname is specified, may be set as “”.
  • shortname (hwString) – The short name (portion without the path) of the include to export. If id is specified, this may be set as “”.
  • export_template (hwString) – The full path and filename of the export template to be used. Paths with spaces must be enclosed in quotes.
  • filename (hwString) – The full path and filename of the output file. Paths with spaces must be enclosed in quotes.
  • reserved1 (int) – Reserved for future development. Must be set to 0.
  • reserved2 (int) – Reserved for future development. Must be set to 0.
  • export_type (int) –
    Flag indicating which entities will be output:
    0 - Only the displayed entities will be output.
    1 - All entities will be output.
    2 - Entities will be output based on their/their parent collector’s output bit (custom output). This bit can be set using the Model.allsuppressoutput(), Model.includesuppressoutput() and setvalue() functions or using the Entity State Browser.
  • string_array (hwStringList) – The string array that contains the additional output parameters.
Example#
Export all entities in the include with ID 10, using the OptiStruct template, to a file named C:/temp/myinclude.fem, skipping the export of connectors#
import hm
import hm.entities as ent
model = hm.Model()
model.feoutput_singleinclude(
  id=10,
  shortname="",
  export_template="C:/Altair/2025.1/hwdesktop/templates/optistruct/",
  filename="C:/temp/myinclude.fem",
  reserved1=0,
  reserved2=0,
  export_type=1,
  string_array=["CONNECTORS_SKIP"])
