Model.jointelement_twonoded#
Model.jointelement_twonoded(n1, n2, orientation, o_node1, o_node2, system1, system2, property)#
Creates a spherical or two-noded joint element.
Parameters:
  • n1 (Entity) – The entity of the first node.
  • n2 (Entity) – The entity of the second node.
  • orientation (int) –
    Orientation option for the element. Use:
    0 - None
    1 - Systems
    2 - Nodes
  • o_node1 (Entity) – The entity of the first orientation node.
  • o_node2 (Entity) – The entity of the second orientation node.
  • system1 (Entity) – The first orientation system entity for the elements.
  • system2 (Entity) – The second orientation system entity for the elements.
  • property (hwString) – The property to which the element points.
Example#
Create a two - noded joint element from nodes with IDs 320,303, orientation nodes with IDs 322,324 and property “shells”#
import hm
import hm.entities as ent
model = hm.Model()
model.jointelement_twonoded(
    n1=ent.Node(model, 320),
    n2=ent.Node(model, 303),
    orientation=2,
    o_node1=ent.Node(model, 322),
    o_node2=ent.Node(model, 324),
    system1=None,
    system2=None,
    property="shells",
