Model.specialelements#
Model.specialelements(DestinationComp, CreatePropMat, sourceCollection=Collection(), targetCollection=Collection(), ElemSize=0, NumLayers=0)#
Creates special elements like gasket elements between a source and target, or updates penta/hexa elements to special elements like gasket elements.
Parameters:
  • DestinationComp (unsigned int) –
    The component to which the special elements will be organized. This is a mandatory option. Valid values are:
    0 - New component
    1 - Current component
    2 - Surface component
  • CreatePropMat (unsigned int) –
    Properties and materials will be assigned to the created elements. This is a mandatory option. Valid values are:
    0 - New property
    1 - Existing property
  • sourceCollection (Collection) – The collection containing the source entities. Valid entities are surfaces, elements and faces.
  • targetCollection (Collection) – The collection containing the target entities. Valid entities are surfaces, elements and faces.
  • ElemSize (int) – The element size to use when the entities contained in the sourceCollection are surfaces.
  • NumLayers (unsigned int) – The number of layers to create.
Examples#
Create special elements between surfaces with IDs 4 and 2 , with size 10 and 3 layers#
import hm
import hm.entities as ent
model = hm.Model()
model.specialelements(
    DestinationComp=1,
    CreatePropMat=1,
    sourceCollection=hm.Collection(model, ent.Surface, [4]),
    targetCollection=hm.Collection(model, ent.Surface, [2]),
    ElemSize=10,
    NumLayers=3,
Update penta / hexa elements with IDs 101 - 110 to special elements#
import hm
model = hm.Model()
# Creating a collection that contains the elements with IDs 101-110
filter_elements = hm.FilterByEnumeration(ent.Element, list(range(101, 111)))
elements_collection = hm.Collection(model, filter_elements)
    sourceCollection=elements_collection,
    targetCollection=hm.Collection(model, ent.Element, populate=False),
    DestinationComp=0,
    CreatePropMat=0,
