Model.sl_meshsurfaces#
- Model.sl_meshsurfaces(collection, file, reserved)#
Performs feature-based meshing of surfaces using an XML config file.
- Parameters:
collection (Collection) – The collection containing the surface entities to mesh.
file (hwString) – The full name and path to the XML config file containing the mesh parameters.
reserved (int) – Reserved for future development. Must be set to 0.
Example#
Mesh all surfaces using the config file “c:/temp/config.xml”#import hm import hm.entities as ent model = hm.Model() surface_collection = hm.Collection(model, ent.Surface) model.sl_meshsurfaces( collection=surface_collection, file="c:/temp/config.xml", reserved=0 )
