Model.verticesmarksuppress#
Model.verticesmarksuppress(collection, break_angle, save_as_points)#
Removes the selected fixed points from their surfaces and gives the option to create free points at those locations.
Parameters:
  • collection (Collection) – The collection containing the point entities to be removed.
  • break_angle (double) – The test threshold used to prevent the accidental removal of points that correspond to corners, which are necessary for proper mesh generation.
  • save_as_points (int) –
    0 - Do not create free points.
    1 - Create free points at the locations of the removed fixed points.
Example#
Suppress the points with IDs 25 , 26 , use a 30.0 degree breakangle#
import hm
import hm.entities as ent
model = hm.Model()
# Creating the collection that contains the points to be removed
point_collection = hm.Collection(model, ent.Point, [25, 26])
model.verticesmarksuppress(
    collection=point_collection, break_angle=30.0, save_as_points=0
