Model.hm_compareentitiesrecursive#
- Model.hm_compareentitiesrecursive(source_surfaces, target_surfaces, tolerance, result_type=1, review_results=True)#
Generates recursive comparison results for entities positioned at any location. Multiple matches can be found for each source entity (a source entity may match more than one target entity positioned at a different location). This must be preceded by a call to
Model.hm_compareinit().These results can then be queried using hm_compareget* APIs, or written to a file using hm_comparewrite* APIs.
- Parameters:
source_surfaces (Collection) – The collection containing the source entities. Valid entities are surfaces or elements.
target_surfaces (Collection) – The collection containing the target entities. Valid entities are surfaces or elements.
tolerance (double) – The tolerance value to use for the comparison.
result_type (int) –
SURFS to SURFS
0 - Basic
Matched (paired)
Unmatched
1 - Full (default)
Matched (paired)
Overlapped
Intersected
Unmatched
2 - Detailed
Matched (paired)
Overlapped (paired)
Intersected (paired)
Unmatched
review_results (bool) –
False - Do not automatically show the graphical comparison results after execution.
True - Automatically show the graphical comparison results after execution (default). This is cleared upon a call to hm_compareend.
- Returns:
hwReturnStatus- Status object
Example#
Write the detailed comparison results file to “ C:/temp / my_compare.txt “ for the recursive comparison of surfs with IDs 1 - 20 and 101 - 120#import hm import hm.entities as ent model = hm.Model() surfs1 = hm.Collection(model, ent.Surface, list(range(1, 21))) surfs2 = hm.Collection(model, ent.Surface, list(range(101, 121))) model.hm_compareinit() model.hm_compareentitiesrecursive( source_surfaces=surf1, target_surfaces=surfs2, tolerance=0.1, result_type=2, review_results=False, ) model.hm_comparewriteresults( filename="C:/temp/my_compare.txt", source_component_id=0, target_component_id=0 ) model.hm_compareend()
