Model.hm_fe_getdvstfile#
- Model.hm_fe_getdvstfile(connector)#
Returns the diameter versus thickness file set on a connector.
- Parameters:
connector (Entity) – The object describing the connector entity.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:dvstFile (str)
Example#
Get the diameter versus thickness file for connector with ID 1#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_fe_getdvstfile(connector=ent.Connector(model, 1)) print("dvstFile", result.dvstFile)
