Model.CE_DetailSetString#
- Model.CE_DetailSetString(connector_id, detail_name, string_value, reserved, force_storage)#
Sets a string connector detail for a single connector.
- Parameters:
connector_id (unsigned int) – The ID of connector to update.
detail_name (hwString) –
The name of the standard string detail, or user-defined string detail, to update. Standard string details include:
ce_collectorname
The component name of the connector entity.
ce_configname
The FE config name of the realized connector.
ce_connectivity
The connector FE connectivity.
independent
FE connectivity
dependent
use_shell_node, etc…
ce_fesolver
The FE solver name.
ce_fetypename
The realized FE type name defined in the feconfig.cfg file.
ce_fe_fileattribute_entids
The entity IDs related to the file attribute option.
entity_type ID_1 ID_2 … (example: “materials 3 6 7”)
ce_fe_folderattribute_entids
The entity IDs related to the folder attribute option.
ce_positionstring
A list containing the entity type, followed by the entity IDs selected to create the connector.
ce_propertyscript
The user property script used for realization.
Full absolute path and file name.
ce_state
The connector entity state.
failed
realized
unrealized
ce_style
The connector style.
app_mass
area
bolt
seam
spot
ce_type
The connector entity type based on its creation.
area
line
node/point
seam
string_value (hwString) – The string value to update for the detail.
reserved (unsigned int) – Reserved for future development. Must be set to 0.
force_storage (unsigned int) –
0 - Do not store user-defined detail.
1 - Store user-defined detail.
Example#
Set the user property script for connector with ID 1#import hm import hm.entities as ent model = hm.Model() model.CE_DetailSetString( connector_id=1, detail_name="ce_propertyscript", string_value="C:/temp/scripts/connectors/test.tcl", reserved=0, force_storage=0, )
