Model.solid_cavity_detect_modify_rims#
- Model.solid_cavity_detect_modify_rims(add_collection, remove_collection, region_id, add_surfs_flag)#
Modify a partially detected cavity by adding and removing rims.
The function
Model.solid_cavity_detect_start()must be called before calling this function to generate the cavities as region entities.- Parameters:
add_collection (Collection) – The collection of the line entities containing edges to add as rims.
remove_collection (Collection) – The collection of the line entities containing existing edges to remove as rims.
region_id (unsigned int) – The ID of the region containing the cavity definition to modify.
add_surfs_flag (int) –
1 - The extracted surfaces are added to the cavity.
0 - The extracted surfaces are removed from the cavity.
Example#
Add a rim represented by a connected set of surface edges with IDs 3 and 4 with a cavity represented by region ID 10,and remove the rim represented by surface edge IDs 7 and 8 . Add the surfaces , as the volume of cavity increases due to this modification#import hm import hm.entities as ent model = hm.Model() model.solid_cavity_detect_start( collection=hm.Collection(model, ent.Surface), all_cavities=1, get_n_cavities=0, max_radius=-1, max_length=-1, min_concavity=0.5, ) model.solid_cavity_detect_modify_rims( add_collection=hm.Collection(model, ent.Line, [3, 4]), remove_collection=hm.Collection(model, ent.Line, [7, 8]), region_id=10, add_surfs_flag=1, ) model.solid_cavity_detect_end()
