Model.hm_getelementnormal#
Model.hm_getelementnormal(element, queryType, queryIndex)#
Returns the normal vector of the specified element vertex/edge/face.
Parameters:
  • element (Entity) – The object describing the 2D/3D element entity to query.
  • queryType (hwString) –
    vertex - query_index is the index of a vertex (node) of a 2D/3D element.
    edge - query_index is the index of an edge of a 2D element.
    face - query_index is the index of a face of a 3D element.
  • queryIndex (int) – The index of the vertex (node), edge or face. The index is 1-based and is ordered the same as the nodes/edges/faces defining the element.
Returns:
Examples#
Get the normal of shell element with ID 100 edge index 1#
import hm
import hm.entities as ent
model = hm.Model()
_, result = model.hm_getelementnormal(
    element=ent.Element(model, 100), queryType="edge", queryIndex=1
print("Normal Vector Components:", result.normalVectorComponents)
Get the normal of solid element with ID 300 face index 2#
import hm
model = hm.Model()
    element=ent.Element(model, 300), queryType="face", queryIndex=2
