Model.hm_getsurfacenormalatcoordinate#
Model.hm_getsurfacenormalatcoordinate(surface, x, y, z)#
Returns the closest point and the components of the normal vector at the point on the line closest to the input coordinates.
Parameters:
  • surface (Entity) – The object describing the surface entity.
  • x (double) – The x-coordinate of the point
  • y (double) – The y-coordinate of the point
  • z (double) – The z-coordinate of the point
Returns:
  • hwReturnStatus - Status object
  • HmQueryResult - Result object containing the output values:
    • closestPointCoordinates (numpy.ndarray) - The closest point coordinates
    • normalVectorComponents (numpy.ndarray) - The normal vector components
Example#
Get the components of the normal vector nearest the coordinates ( 100,50,25 ) for the surface with ID 341#
import hm
import hm.entities as ent
model = hm.Model()
_, result = model.hm_getsurfacenormalatcoordinate(
    surface=ent.Surface(model, 341), x=100.0, y=50.0, z=25.0
print("Closest Point Coordinates:", result.closestPointCoordinates)
print("Normal Vector Components:", result.normalVectorComponents)
