Model.createpointsbetweenpositions#
Model.createpointsbetweenpositions(x0, y0, z0, x1, y1, z1, count, end_points, system_id)#
Creates midpoints between two geometric positions in space.
Parameters:
  • x0 (double) – The x-coordinate of the start position.
  • y0 (double) – The y-coordinate of the start position.
  • z0 (double) – The z-coordinate of the start position.
  • x1 (double) – The x-coordinate of the end position.
  • y1 (double) – The y-coordinate of the end position.
  • z1 (double) – The z-coordinate of the end position.
  • count (int) – The number of midpoints to create.
  • end_points (int) –
    0 - No point at either end
    1 - Create a point at the start position
    2 - Create a point at the end position
    3 - Create points at both ends
  • system_id (Entity) – The system entity that positions the end points in space.
Example#
Create 7 points between posistions ( 1.89 , 8.83 , 8.84 ) and ( 8.68 , 1.82 , 1.83 )#
import hm
import hm.entities as ent
model = hm.Model()
model.createpointsbetweenpositions(
    x0=1.89,
    y0=8.83,
    z0=8.84,
    x1=8.68,
    y1=1.82,
    z1=1.83,
    count=7,
    end_points=0,
    systemid=None,
